603,960 active members*
2,209 visitors online*
Results 1 to 9 of 9
    Jul 2018
    8
    write protect in macro input
    I want to edit macro variable input during write protect key is in OFF condition or removed from Fanuc Oi-TF model panel
    Feb 2006
    1792
    Re: write protect in macro input
    Some variables are read-only type. These cannot be edited.
    Jul 2018
    8
    Dear Sir,
    I have attached a file , i need help to edit
    Feb 2013
    22
    If I understand correctly your just trying to name the variable, I am not familiar with the Fanuc Oi-TF control but I do know that in other Fanuc controls you can set your data like this:
    in MDI mode you would write SETVN500[xxxxx];
    then hit cycle start.
    xxxx is whatever your going to name it
    Jul 2018
    8
    I have tried SETVN500[ABCD] in MDI and executed but name is not changed and also there is no alarm message. My intention is to change [RAPID ST] as [STRAIGHT]
    Feb 2006
    1792
    Insert a semicolon (EOB) in the end, bring cursor to the first word, and then hit CYCLE START.
    Jul 2018
    8
    I tried by typing SETVN500[ABCD]; as per your guidance still not working, this is my whatsup no. 9880716976 can i chat with you.
    Feb 2006
    1792
    Please check the syntax of SETVN in your manual (under macro-programming section). Maybe model F is a bit different.
    Jul 2018
    8
    Fanuc Oi-TF model is executing SETVN500[ABCD]; properly- may be this variable 500 label is protected. I am using in Centerless grinding machine with Oi-TF controller. I dont know how to enable write
  1. write protect in macro input
    By sureshkk029 in forum Fanuc
    Last Post: 07-22-2018, 04:08 PM
  2. Disable write protect key functionality
    By myhäje in forum Mori Seiki lathes
    Last Post: 09-15-2015, 07:56 PM
  3. 300- alarm. write protect
    By alexandermatovu in forum Fanuc
    Last Post: 06-23-2012, 01:56 AM
  4. Fanuc 11m parameter write protect
    By BrianM03 in forum Fanuc
    Last Post: 06-14-2010, 04:17 PM
  5. FANUC 15T Write Protect
    By bmlw in forum Fanuc
    Last Post: 10-11-2008, 08:47 PM
