603,942 active members*
2,642 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Writing Nc Script For Haas Vf
Results 1 to 8 of 8
    Aug 2007
    Red face Writing Nc Script For Haas Vf
    I tried to write a simple rectangular program for a HAAS VF series machine and when I try and load it on the machine I get an alarm
    430 file unexpected end of input ending % sighn not found.
    I tried to put a % sign at the end but still same alarm.then I tried to view the program on Predator and it was unreconizable script with a g code here and there. What am I not doing right??? anybody??? Craig [email protected]
    Oct 2005
    859
    I dont know much about Haas controls but post the code from the file so we can take a look.
    Aug 2003
    449
    It is more likely that the file format itself is causing the problem.
    Do this:
    On the NC-CAM window click on File and then Setup.
    In the Extension for Text files field put in .tap and click OK.
    Now save the file, making sure to select Text files (*.tap), from the save as field.
    The program should open fine on the control after that. The issue is that you likely saved the file as a .cnc file. These files are encoded so that the association with the drawing is maintained (position in the drawing screen = current location indicated in the program). This format would appear as described if you open the file in a text editor other than BobCAD.
    Regards
    Jan 2005
    71
    Cool Please post the file
    I have 4 Haas mills and use Bobcad. I might be able to point you in the right direction.
    Rules of my Road: Don't do what you will regret! Never regret anything you do!
    Aug 2007
    Just wanted to say thank you to "THE ONE".
    I changed the settings in the setup to .tap and it worked like a charm and loaded fine.Thanks again. Craig
    May 2011
    Question just not geting it
    Quote Originally Posted by The One View Post
    Do this:
    Regards
    am having the same problem but I dont get what you mean by NC-CAM window is that the bobcam window or the predator? I open both and click on file and don't see a setup if you could help that would be great thx
    Mar 2010
    1852
    You are replying to a post that is almost 5 years old. Not the same programs etc.
    Post your question/problem anew and we will help you out.
    Mike
    Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
    Dec 2008
    4545
    I think they are talking about V21.. In the newer versions, you right clcik CAm Part-Milling tools, and choose settings. On the first machine tab is a place to set what the extension of saved nc files are...
  1. Writing your own CNC Control Software
    By mechona in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-09-2007, 03:29 AM
  2. writing post processor
    By peppignolo in forum CNC Machining Centers
    Last Post: 03-06-2007, 11:29 AM
  3. imagine writing the code for this!!!!
    By bearracecars in forum Waterjet General Topics
    Last Post: 02-19-2007, 10:46 PM
  4. Artcam postprocessor writing
    By simonl in forum ArtCam Pro
    Last Post: 01-07-2007, 05:25 AM
  5. Writing words
    By JDARSNEK in forum G-Code Programing
    Last Post: 11-27-2006, 09:42 PM
