603,794 active members*
2,851 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Writing programs on a 5020L Control
Results 1 to 10 of 10
    Oct 2008
    20
    Hi all,
    We just picked up a new(to us)1995 LNC8 Cadet. We don't have any communication cables hooked up to it yet, but I've been nosing around the control, and I don't see any way to write a new program on the control.
    I can MDI 1 block at a time, but if I don't see any way to actually create a new program.
    What am I missing on this thing? I can't imagine not being able to write programs at the control.
    Thanks for any input.
    Keith
    Jan 2008
    575
    Go into EDIT mode push the soft key "edit" F4 or something, enter a short name with no spaces, that starts with a letter (as apposed to a number) push write and you have a blank page to start writing.
    Hope that helps, Robert
    Oct 2008
    20
    Thanks littlerob. I've been perusing the manuals, and I didn't see that anywhere. Worked like a charm
    Dec 2008
    79
    Okuma's manuals are certainly the worst on the market....
    don't forget to press "edit quit" when you quit editing
    Oct 2008
    20
    Quote Originally Posted by Goldorak View Post
    Yeah, I found that one out the hard way yesterday. Fortunately, it was just a little bs trial program.
    I haven't programmed a lathe in 10 years now; so I'm trying to shake the rust.
    Dec 2008
    79
    if you got questions , don't be shy
    we got 3 lathes like yours here , i got about every problem possible with them since 15 years, one of our cadet is 20yo and still run like a charm it hold .0002 tolerances very easily
    Apr 2009
    1273
    Just FYI ...
    If you forget the edit quit, you have one chance to recover the file by trying to edit a new file and typing ;R after the file name.
    This works too if you run out of memory and need to delete a file to make more room.
    As far as the Okuma manuals being the worst...don't bet on it. I've seen some...yikes! The Okuma's look pretty good when compared to them!
    (yes Jinglish and all)
    Dec 2008
    79
    good to know
    the thing i don't catch about okuma, is that on the same controller on a mill (OSP5020M) you don't need to "edit quit", the ,min file is automatically saved when you quit editing.....
    Dec 2008
    3214
    Has anyone tried turning their machine OFF while still in edit mode ???
    ---your program is gooooone to the great beyond
    and ;R ( restore ) won't work
    Apr 2006
    825
    Quote Originally Posted by Superman View Post
    Now Steve... why why why would you want to TURN OFF the machine in the middle of editing the program? Of course you can not control the power if it fails externally... but to expect "Recover" to work would be a real stretch :nono:
  1. Heidenhain control / programs
    By Rogue in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-30-2015, 07:01 AM
  2. FANUC OM CONTROL PROGRAMS
    By jvmjr1973 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-20-2008, 02:18 PM
  3. Problem loading programs into DX32 control
    By D.Blair in forum Bridgeport / Hardinge Mills
    Last Post: 03-05-2008, 03:32 AM
  4. Writing your own CNC Control Software
    By mechona in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-09-2007, 03:29 AM
  5. lock programs with fanuc 16/18 control
    By Heavy D in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-31-2006, 12:09 AM
