Hello everyone,
I bought an used harmonic drive from Ebay, it claimed to be a model of SHF-17-50-2UJ and of reduction ratio 50:1. Because there was worn out in cross roller bearing, I needed to disassembled it and replace a new one in it. At first, I didn't check the reduction ratio before I did the disassembly....
After everything done and also installing it to my 5th axis. I checked and found the ratio is incorrect! It actually is 51:1.
From the outside looking and the marking on the housing, it looks an original "HD" brand. What is the wrong with the ratio? Is it due to my incorrect assembly of spline into the inner gear ring, but the drive runs smooth?? Will one of the gear inside is not an original brand and of incorrect teeth number?
Can anybody help?
Thanks,
