587,307 active members*
3,812 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > X axis briefly going the wrong way ARG
Results 1 to 4 of 4
    Mar 2011
    Hello all,
    I had a new problem spring up on me just recently that is leaving me scratching my head. When the machine runs the X axis goes the opposite direction from where it is supposed to go for just a brief moment, then goes the right way. I have the A axis slaved to the X on the other side of the gantry and it does not seem to be doing that, so it must be something related only to the X axis.
    I had been planning on replacing my controller computer because the one that has been running it was quite old. Once that problem surfaced I figured it may be something with the parallel port going bad or something, so I configured the new computer and set it up only to find that the problem persists.
    So what could it be on the driver/motor side? All connections seem to be tight. I have not moved anything around.
    Andy thoughts?
    THANKS!!!
    May 2007
    380
    i had a similar problem that turned out to be a bad pin connection in the parallel port at the computer. I sprung the pin slightly and the problem went away.
    John
    Mar 2011
    Fixed!
    Okay so I was standing out at the machine running it back and forth waiting for some lightning to strike my brain when I noticed a small arc by the wiring going into the motor. Lo and behold, one of the butt connectors had broken in half so that wire was hardly making any contact. New butt connector = fixed machine!:banana:
    Thanks for the help!
    I had the same thing happen today. I ended up removing the db9 connector and soldering the wires. I also inadvertently cut the wires with the Gecko 540 powered up. Luckily I had a spare! Now it is off to buy a replacement drive!
    Sean
    www.FreeCNCPlans.com
  1. X & Y axis going the wrong way
    By utengineer04 in forum Mastercam
    Last Post: 04-20-2011, 07:51 PM
  2. Z axis going in wrong direction
    By erkiwi in forum CNC Machine Related Electronics
    Last Post: 01-20-2010, 11:43 AM
  3. X axis going wrong dir.
    By bogger44 in forum Waterjet General Topics
    Last Post: 08-02-2009, 03:42 AM
  4. What's the verdict? (briefly!)
    By tenaja in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-31-2006, 08:14 AM
  5. integrex 200 II SY b axis wrong direction
    By smile in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-07-2006, 05:09 AM
