587,917 active members*
3,637 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > X AXIS Freezes and all other axis keep moving
Results 1 to 10 of 10
    Apr 2018
    19
    Hello all, I'm having an issue with my machine. I have the older Vcon machine with a CRP800-00E-8 nema 34 plug and play setup. On longer runs, sometimes my X axis (gantry) will stop moving. Mach 3 continues to run and my z axis and both Y axis motors continue like there is no problem. This problem has been plaguing me on and off for a few years now. It was intermediate so I never cared that much but just chalked it up to Mach 3. Problem is now a days mistakes like that cost me several hundred dollars as I'm working with much pricier materials and end mills. I have to get this fixed.
    Recently I changed my PC from an older model to a newer one and installed the latest version of Mach 3 on Win 10. Previously I was running Mach 3 on XP on the old pc and still had the issue. So I know it's not my PC. If anyone can help with trouble shooting, I would appreciate it.
    Apr 2010
    82
    Re: X AXIS Freezes and all other axis keep moving
    My first guess would be cabling. I would run some gcode that exercises the machine for a long time and work my way around the machine manipulating cables and connectors to see if I could make it fail. Something like a circular contour with a very small stepdown running at a relatively slow speed should give you lots of time to check out all the cabling.
    Apr 2018
    19
    Well I did 2 runs each today, both over 2 hours and no problems. I'm thinking maybe noise from my VFD. It's just so random. It'll do 20 runs flawless then out of no where X axis problems. I loaded up mach 4 today. I think I'm going to try it for a while and see if the problem comes up.
    Mar 2003
    35538
    Noise from the VFD would not stop one axis.
    I'd first swap cables between the bad axis and a good one, and see if the problem moves to the other axis.
    If not, then try swapping drives.
    My guess is a cable or connection issue as well.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Apr 2020
    15
    CFandZ, Quite interesting. I have had the same problem since 5/2020 when I bought the machine. Some of the following notes may be helpful to you in diagnosis.
    Here is what I discovered:
    Stepper motor with factory damaged winding, I took it apart and saw it.
    Swapped motors and the problem went from Z axis to the X axis.
    Then the problem started again on the Z after getting new parts.
    Last night it started again on the Z.
    Each cycle has resulted in Avid giving me new parts. Since it is intermittent, assurance of a fix is uncertain. They gave me: 1) new control box, 2) new drivers, 3) 2 new motors and a cable
    It is hard to be certain what is up, I know moving a defective motor moved the problem (along with seeing the winding damage plainly).
    Feel free to follow my document on the malfunction, here: https://docs.google.com/document/d/1...it?usp=sharing
    The document reads from bottom upward chronologically. I welcome any conclusions you may infer after comparing the events.
    Apr 2018
    19
    Hello Insect, looks like you have been through the wringer with this problem. Well today I was doing a probing action and again my X axis stopped, All my other axis and mach 4 kept going. I opened up the control box and the top controller was flashing red. No power was going to the motor. I checked the wire but didn't see an issue. The only thing that fixed it was cycling the power. Everything appears to be tight and secure in the box. I think I'll send Avid an email and see what they recommend. This problem is costing me money
    Apr 2018
    19
    Well it certainly is not a VFD issue. I was doing a probing run today and it happen, I did see one of the drives were flashing red after the stepper lost power. I'll swap that one with one of my Y axis motors. All though it's really hard to tell what driver goes to which motor.
    Apr 2018
    19
    Quote Originally Posted by Insect View Post
    I just looked at your video. I don't know if it is your issue but I know vacuums can create static electricity. I know when I was using a dust collection system I had to ground it. I know it will be messy but it may be worth trying a few runs without your vacuum hose.
    Apr 2018
    19
    Per Avid, looks like I have a bad driver. I was informed generally when a driver starts to blink red it indicates it's going bad. I have one on order. I'll report back after I've gotten the new one installed and run a dozen or so runs.
    Apr 2018
    19
    As always, Gerry is correct. There was a short in a wire. I've had dozen of hours ran after the fix with no problems. I did also change out the driver.
  1. Locking 4th Axis Freezes Machine
    By tmcgh in forum Fanuc
    Last Post: 01-03-2019, 09:50 PM
  2. Slaved Axis accrued error on A axis while moving
    By Xnaron in forum Mach Software (ArtSoft software)
    Last Post: 07-05-2016, 02:36 AM
  3. axis not moving Only DRO moving on mach3 screen for cnc router 6040
    By bingaom in forum Charter Oak Automation Support Forum
    Last Post: 09-09-2014, 08:54 AM
  4. Replies: 12
    Last Post: 02-07-2014, 02:40 PM
  5. a problem with slaved A-axis moving properly relative to Y-axis
    By zool in forum Mach Software (ArtSoft software)
    Last Post: 07-06-2011, 03:45 AM
