587,731 active members*
3,148 visitors online*
Page 4 of 4 234
Results 61 to 66 of 66
  1. #61
    Re: X axis is off center
    I have not disagreed with any method anyone uses, so why the fuss (chair)
    No matter how you do it, there is still metal to metal contact and some damage will happen to the cutter especially if your cutter is carbide, HSS is a little more forgiving
    I don't want to muddy this thread any further and I'm done after this , but is the above not disagreeing , or the dump you took on cadcam and his teaching skills ?
    you can make assumptions of another man's capabilities , except any assumption will probably be a fools assumption
  2. #62
    Aug 2009
    1573
    ...X files
    Paper your plastic..rock the house
  3. #63
    Jan 2005
    15362
    Quote Originally Posted by metalmayhem View Post
    Are no it is not disagreeing with anything, it's just a statement saying what happens when you use this method, which is known throughout the industry, this is not something I came up with or even care about
    I do know one thing, that this method you use is primitive and in efficient for todays standards, For under $500 gets you a 3D probe that can work with any machine
    Everything you have posted is not relevant to this thread, this is not about you and what you do or can do (nuts)
    The Op started this thread and wanted help with his probing and work setup, not about you what you do or your method
    Mactec54
  4. #64
    your nuts
    good luck with your piece of plastic
  5. #65
    Jan 2005
    15362
    your nuts
    Nuts yes everyone is a little Nuts so that's a good label
    As I said I use Probes so don't have to roll the Dowel or use the plastic which is good for anyone just starting to learn how to do manual Z axis offsets
    Mactec54
  6. #66
    Apr 2003
    3578
    Well this conversation continues to go forward. I am not worried about my methods of teaching or doing. I continue to help other's grow in there careers that make me feel good.
    If I can help I will.
    Mactec54 thank you for your opinion I think it has been well noted. I am sure we will see again here or at one of the shows again.
    Quick not I will be closing this topic as it has gone it way.
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
Page 4 of 4 234
  1. madcam 5 axis center of spindle axis
    By jeriesfacouseh in forum MadCAM
    Last Post: 10-21-2016, 03:09 PM
  2. Replies: 17
    Last Post: 09-14-2015, 02:48 AM
  3. Holes does not center on X axis?
    By dahlman in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 02-18-2014, 01:01 AM
  4. Used BP, Y Axis must by worn out in the center
    By Wade in forum Bridgeport / Hardinge Mills
    Last Post: 03-31-2010, 02:19 AM
  5. Rotary axis+off center?
    By sdeering in forum Mastercam
    Last Post: 01-23-2010, 05:20 AM
