I'm retrofitting a BOSS 4 with the original drives & steppers. All axis (XYZ) were working yesterday. Fuse 6 blew (I think it was 6. It's the 1.4A on the Limit overide circuit.) Replaced it today, now no X Axis
I can jog Y & Z but not getting any movement on X. I can hear the X axis stepper hum when it gets the signals from mach3, and the mechanical counter twitches.
Here's what I've Tried in troubleshooting problem.
Checked current across fuse12 & set ACC P1 to 8.2amps static.
Swaped SMD board with Y. Y works with X axis SMD board, X does not move with Y board.
Swaped pins 1&2 with 3&4 on K8 connector. Y Axis moves when 3&4 are connected to pins 1&2.
Checked continuity from K8 pins 1&2 with the card edge connector on X axis SMD socket.
SMD Board swap should have ruled out bad SMD Boards. K8 Pin swap should have ruled out bad BOB.
Any help would be much appreciated.
