603,355 active members*
4,044 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > X rail spacing question, 40" x 36"
    Dec 2011
    I am building my X axis for a fixed gantry/moving table design. The base is 40"x36", with the linear rails running on the 36" length side.
    I have two rails, what is the optimum spacing, that is distance apart to prevent racking and to support the moving table most efficiently?
    This will be for soft metals and woods, planning on using a Bosch 1HP spindle. Frame is 100% 80/20 15 series extrusion.
    I suspect the answer may differ based upon the flex of my table if any. Currently I'm planning for a homemade ply/mdf spoil board with T-slot rails.
    Mar 2003
    35494
    What kind of bearings? Do you have an image of the design?
    Lots of variables involved here, but generally, the farther apart the better.
    Are you driving the gantry from both sides, or from the center.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. Cant find "loose" linear rail for floating head
    By Beefy in forum Waterjet General Topics
    Last Post: 11-25-2010, 03:36 PM
  2. is this useful? aluminum "rail"
    By desbromilow in forum Linear and Rotary Motion
    Last Post: 06-18-2010, 06:28 PM
  3. Linear rail & slides or "V" bearing & track
    By CNCCajun in forum Linear and Rotary Motion
    Last Post: 05-07-2009, 08:45 AM
  4. Replies: 23
    Last Post: 02-25-2009, 10:49 PM
  5. Determining "speed hole" spacing and size? (weight saving cutouts)
    By douglasco in forum Mechanical Calculations/Engineering Design
    Last Post: 08-04-2008, 09:26 PM
