603,969 active members*
3,151 visitors online*
    Apr 2012
    91
    X Y Probing in 2010 sceenset
    Is there a method of X,Y, probing, (on an all metal setup) to touch off with my tool. Rather than using my probe and without using my moving plate?
    If not, what is common all metal methodology please?
    Mar 2003
    35494
    Re: X Y Probing in 2010 sceenset
    You can use an isolated touch plate against the workpiece, and probe to the plate with the tool.
    Just enter the plate thickness in the wizard.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Apr 2012
    91
    Gerry - Yes I am currently doing this with my moving plate. Trying now to make a tri-cornered isolated block fitted with independant x,y & z touch plates to snap onto a square corner with rare earth magnets.
  1. Probing
    By kstrauss in forum Tormach Personal CNC Mill
    Last Post: 11-25-2014, 05:22 AM
  2. Probing inside corners with the 2010 Screenset
    By Megaplow in forum Screen Layouts, Post Processors & Misc
    Last Post: 01-23-2014, 08:18 PM
  3. Probing in a TM-1P
    By HayreAss in forum Haas Mills
    Last Post: 01-15-2012, 02:32 AM
  4. edgcam 2010 and inventor 2010
    By inflateable in forum EdgeCam
    Last Post: 03-22-2010, 09:03 AM
