Originally Posted by
spaceballs_3000
X2 Machine has been up and running and cutting pretty good.
Only one problem currently left.
I notice that when I apply pressure (with finger) on the spindle head horizontally (from left to right) while running it make an loud vibration noise (like prop plane taking off) it happens when not even milling anything.
It happens on any speed, and seems random, when it starts, I change the spindle motor speed and it goes away. When it does happen it does when milling, it does not leave a clean cut on both sides of the stock.
you can kinda hear it in this view (30 seconds in) it's much louder in real life.
Only thing I can think of is my Z gibs are loose, which would be a pain to adjust as the Z fusion kit mounting hardware covers one or two of the gib adjusters.
Any ideas on what is wrong?
