587,180 active members*
4,248 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > X2 spindle motor trips too easily!
Results 1 to 4 of 4
    Apr 2005
    862
    Not seen this problem reported in any searches. Basically I can trip out the motor overcurrent circuit on my X2 by lightly gripping the spindle while it is rotating - or speeding up too quickly. Certainly, there isn't enough torque available to do any cutting. This happened after I had a trip event while cutting heavily with heavily worn motor brushes. The heavy cutting pushed the motor over the edge and there was a lot of arcing followed by the motor tripping out. I took out the brushes to find them almost non-existent and the springs were brittle and cracked up from the heat.
    I replaced the brushes with new ones but now I have this easy tripping problem. There's nothing binding up the transmission, and I can't see any debris around the commutator when I opened it up. The comm was worn quite a bit and I cleaned the surface of it a bit to improve the contact with the brushes, no effect though. Maybe there's a component in the speed controller that could be damaged causing this fault? Help would be much appreciated! I need to cut parts pretty soon.
    Feb 2007
    127
    It could be the plastic that holds the upper shaft bearing has melted and deformed causing the armature to ground out due to play. Thats what happened to my motor.(flame2)
    Robert
    Apr 2005
    862
    For anyone who stumbles on this thread in the future I thought I would post the solution to my problem.
    One of the 2 power resistors in the motor controller had snapped a leg, these resistors are used to sense the current being drawn by the motor and engage the trip when the limit is reached. I re-soldered the broken leg and everything is fixed. My thanks go to Hoss for supplying a link to a very useful PDF (http://www.modelbrasscannon.com/ServiceManual.pdf), and to John Gerling for writing the PDF. A useful document to have even if your motor controller is currently working I would suggest...
    Dec 2007
    362
    Thanks for the info. I hope I never need to use it.
    Regards
    Geoff
  1. M function feed hold tell switch trips?
    By D.D.Machine in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-28-2007, 06:34 PM
  2. Mill trips in middle of running
    By cut2spec in forum Benchtop Machines
    Last Post: 02-28-2007, 02:19 AM
  3. Circuit breaker trips out?
    By Splint in forum CNC Machine Related Electronics
    Last Post: 12-11-2005, 04:24 PM
  4. mitsubishi meldas control trips breaker
    By imwllc in forum Uncategorised MetalWorking Machines
    Last Post: 07-30-2005, 06:02 PM
  5. Easily trace an image into your CAD
    By Graphcon in forum News Announcements
    Last Post: 11-14-2003, 01:30 PM
