587,374 active members*
4,556 visitors online*
Results 1 to 5 of 5
    Oct 2011
    141
    X3 Motor Pulley / Belt Pitch?
    Does anyone know what type of spindle motor pulley and belt type is used on the X3 mill? It seems to be some type of weird 6 mm pitch. I'm trying to replace the spindle motor with an AC servo and would like to get some compatible belts and pulleys from a place like Stock Drive Products.
    thx
    Nov 2009
    724
    Dont quote me but I believe it is a GT2 5mm pitch
    JTCUSTOMS
    "It is only when they go wrong that machines remind you how powerful they are."
    Clive James
    Oct 2011
    141
    Quote Originally Posted by cornbinder23 View Post
    JTCUSTOMS
    I believe GT2 has curvilinear teeth. The replacement belt that came with the X3 has trapezoidal teeth. It just has a weird 6mm pitch. Looks like I'll either modify a spare motor pulley from Grizzly or replace the pulleys\belts with something more standard.
    Nov 2009
    724
    You are correct sir! it does have curvilinear teeth, but I mis-read your post that is the belt for the SX3, suprises me that they would use something different on the X3.
    JTCUSTOMS
    Clive James
    Oct 2011
    141
    JTCUSTOMS
    I believe the curvilinear belts can handle more power. Maybe they switched to a different belt on the SX3 due to the bigger motor and direct drive.
  1. Toy Motor Brass Belt Pulley
    By rwburbage in forum Employment Opportunity
    Last Post: 11-15-2012, 02:45 AM
  2. Belt/Pulley for Servo - Which Pitch? Too many choices?!- I'm lost.
    By Ducatikid in forum Community Club House
    Last Post: 02-02-2011, 05:52 PM
  3. HELP - Belt/Pulley Selection - What Pitch? too many choices!?
    By Ducatikid in forum Linear and Rotary Motion
    Last Post: 01-20-2011, 07:15 PM
  4. ballscrew pitch vs. gear/pulley reduction
    By Hans_G in forum Linear and Rotary Motion
    Last Post: 06-22-2009, 07:12 PM
  5. X3 belt size/pitch
    By trcons in forum Benchtop Machines
    Last Post: 07-26-2008, 03:40 AM
