603,960 active members*
3,794 visitors online*
Results 1 to 7 of 7
    X3 Z Axis Backlash Issue
    Hello,
    Been using my CNC Fusion Deluxe X3 ballscrew conversion for a while, and love it. I have ignored some Z axis issues as it was not important for what I was doing. Now it is....Imagine that!
    I have about .030" backlash in my Z axis. It appears to be coming from the bottom of the screw where the collar and pulley are. I have retightened the collar several several times, and .009" is about the best I can get it. What is the trick to get better accuracy on the Z axis. My X & Y are great, normally less than 001".
    Donald
    Mar 2008
    3655
    Do you have a threaded nut on the bottom of the screw? Make sure the set screws in the pulleys are very tight. Also, a loose timing belt can cause backlash. The BELT tension needs to be very tight.
    CR.
    It is not the belt or pulley. I only have a collar at the bottom, no nut.
    I can see the actual ballscrew moving up and down when I change directions a slight bit. I know it is there and the collar is loose, but how do I tighten it more....It would be nice if it had a nut like the X & Y do.
    Donald
    May 2008
    18
    It might help if you over counter balance the head so that it has a permanent upward thrust of about 5 lbs. This will make it look like a cut is actually on so that the head cannot drop.
    Dave
    I have my gibs tight and I cannot hardly any movement in the actual head. I can SEE movement in the bottom bearing hold where the collar is. I have lifted the collar with a screwdriver and tightened it and got it down from .030" to .009" but I can still see the actual screw going up and down when I change the direction of the head movment.
    Donald
    Mar 2006
    304
    a) does the kit use AC bearings or the stock thrust bearings? (I'm not intimately familiar with their kit)
    b) can you thread the screw to accept a nut?
    I run a tight gibb on the Z axis with AC bearings and a nut for preload in my conversion and the only backlash I get is induced by the fact that I skimped and only used a single nut on the Z axis. Tax return this year might get me a preloaded nut to replace the simple nut currently on there if the economy doesn't kill me first.
    My backlash is between .001 and .002 on a full column move with EMC2's BL compensation running and I haven't touched the preload on the screw since the day I installed the screw.
    edit -
    Another idea - try locking the head in place (if you still have the gibb lock installed) and jogging the head up till the stepper stalls, then jack up the collar and tighten it. That might put enough downforce on the top of the bearing to give you more preload. Worth a shot?
    /edit
    Greg
    Every day is a learning process, whether you remember yesterday or not is the hard part.
    www.distinctperspectives.com
    Mar 2008
    3655
    Hi Donald. The newer CNC kits come with a nut instead of a collar. I'm sure Michael made the change for this reason. If you email him and explain the problem, maybe he would be willing to exchange your z ball screw for a newer type with a nut.
    CR.
  1. odd X Axis issue
    By smittys800 in forum Fadal
    Last Post: 08-04-2009, 06:42 PM
  2. 4th axis power issue
    By Legion99999 in forum Syil Products
    Last Post: 01-16-2008, 07:48 PM
  3. Y-Axis issue
    By studysession in forum Machines running Mach Software
    Last Post: 12-28-2006, 09:11 PM
  4. A axis brake issue
    By nervis1 in forum Post Processors for MC
    Last Post: 04-18-2006, 02:46 AM
  5. Leadscrew backlash nut issue.
    By jaydee116 in forum Uncategorised MetalWorking Machines
    Last Post: 12-14-2004, 01:57 AM
