603,923 active members*
3,317 visitors online*
Results 1 to 13 of 13
    Oct 2005
    38
    XP parallel port control
    hi all
    i made an interface board and unipolar dirver board from pminmos site.
    he helped me so much thanks phil. anyway
    we control the boards they r working but i couldnt control the stepper from my pc?
    how can i control it?
    please help me? it is so urgent.
    turbocnc or mach3 or mch2?or whatever? how can set them up?please show me
    Jun 2003
    3312
    A little clarification. Stormelf has Windows XP, he is looking for software now. The interface and driver checkout without the PC. I'm not using XP to control hardware, anybody have any suggestions?
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Mar 2003
    35494
    Download the latest version of Mach3 and try it. It's free for up to 1000 lines of g-code. www.artofcnc.ca
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Oct 2005
    38
    i download mach also?but i couldnt drive mt stepper? i think there is a different setup?
    i try to make pin setups but how can i give turn to my stepper?
    Mar 2003
    35494
    Go to www.machsupport.com and watch the tutorial videos. They explain how to set it up and get it working far better than I can explain here.
    Gerry
    Oct 2005
    38
    thanks i am going to look it
    Jan 2005
    1695
    I'm using mach2 with winxp without problems. I found that certain drivers can screw up the port and make it not work.
    Oct 2005
    38
    can you please send them to me?
    Nov 2005
    27
    I am also having problems with XP
    I too have been making my own Printer-port interface as a prelude to re-using some driver boards I built many years ago.
    Testing with the OCXDriverTest simply locked-up the computer, even after re-loading Mach2 and re-booting.
    Following Art's advice in the optimisation XP.txt file, I found I could get ~some~ sort of control if I set my computer as a 'Standard PC'.
    Then the OCXDriverTest worked fine, and I had a fairly steady 'pulse rate'. But when I revert to ACPI computer (needed to enable my Local Area Network) then the pulse rate is hopping around madly and I get zero 'output' to my interface.
    I am seriously wondering about using a (commercial) USB interface instead of the printer port, partly to reduce the number of variables I'm juggling.
    Geoff Probert
    Apr 2005
    421
    Quote Originally Posted by geoff p
    Geoff Probert
    A USB to parrallel will not work for CNC control. For most software the parallel port needs to be directly contolled by the driver and a USB interface does no allow this.
    The ACPI inteface should not be a prereq for networking. If the board is stuborn about it I would get a PCI slot NIC for a couple bucks off eBay.
    Jun 2003
    1365
    geoff, did you reboot your computer after installing mach2? In the manual it says theres a second driver that might fix your situation. first try to uninstall mach2 and install it again.
    What kind of pc are you running? mach software doesnt run on some laptops, including I think all centrino laptops(pentium M)
    Jon
    Nov 2005
    27
    In answer to Jon, yes I did re-boot after re-installing. That's when I tried the steps in the optimization guide.
    Am I right to guess from DieGuy's note that Standard PC mode is normal? And what is a 'NIC' please?
    Jun 2004
    463
    NIC - Network Interface Card, ie a PCI ethernet card.
