587,374 active members*
3,329 visitors online*
IndustryArena Forum > CAM Software > OneCNC > xr3 system requirements.
Results 1 to 6 of 6
    Oct 2008
    12
    Hi Folks i have just ordered myself a copy of onecnc xr3 pro to use with my haas tm1. cant wait for it to arrive and start making some stuff !
    Just want to get an idea of what computer systems you good folks are using and how they perform. There are so many price ranges and specs its confusing.
    Probably thinking laptop, gives a bit more flexibility but am open to ideas.
    Just to get things rolling, here is a spec i pulled for a :
    Dell Vostro 1700 Laptop T7500 2.2Ghz 3.0GB RAM.
    CPU Type:Core 2 Duo 2.2Ghz
    Hard Drive Capacity:160 GB
    RAM:3.0 GB
    Optical Drive: DVD+/-RW
    Video Type:NVidia GeForce 8600M GT graphics card
    Video Memory:256 MB
    LCD Max Resolution:1440 X 900
    Screen Size:17"
    Display Technology: WXGA+
    Firewire: Yes
    Bluetooth:Yes
    WiFi Enabled: Yes
    SD Card Reader: Yes
    HDMI Socket: No
    Price £450.00 ($738) including tax
    Good or Bad ?
    Thanks in advance for the help.
    paul h
    Mar 2003
    4826
    That will likely be fine. OneCNC does not require exotic hardware, but you can always make use of the fastest CPU/MB combo when it comes to intensive toolpath calculations for 3d toolpaths. I run OneCNC on hardware from 2 to 5 years old, and it runs well enough most of the time that I've no incentive to upgrade my equipment til it dies Mind you, I don't run many multi-megabyte nc programs.
    Just stay away from pre-Athlon64 CPUs, if you're an AMD user, and stick with either ATI or Nvidia video so you have reasonable hope of seeing regular driver updates, in case of a video problem.
    First you get good, then you get fast. Then grouchiness sets in.
    Oct 2008
    12
    Thanks Huflungdung its good to know i am thinking along the right lines. and dont have to spend megabucks
    cheers
    Paul H
    Nov 2004
    55
    Cool
    Hi Paul
    Good choice , i have XR3 running my Tm1 and runs like a dream.(forget Haas quickcode!! )
    As far as Pc concerned would personally always go for a Desktop over Laptop as cheaper for better spec and to me laptops have always seemed a little sluggish , but if you need to take it with you or out on the road Desktops are a bit awkard
    Have fun !!
    Dont forget to join the Onecnc users forum too, great place for help.
    Cheers Kev :cheers:
    Oct 2008
    12
    Thanks Kevh, i have been tryin to figure out the haas quick code but there seems to be some bugs in it. I need to talk to the haas engineere for guidance. (Or not if onecnc does the job).
    I have read good things about the onecnc user forum and am sure will have plenty of questions
    Due to my haste in trying to spec a computer i didnt properly search this forum and have found this thread http://www.cnczone.com/forums/showthread.php?t=76715
    that basically answers my question. oh well i did say i was a newbe!!!!
    Thanks for the replys
    Paul h
    Nov 2004
    55
    Hi Paul
    I had my tm1 a couple of weeks to get to know the basics then purchased Onecnc and havent used quickcode since got the engineer to turn it off even and have the normal Jog page!
    Even if it is drilling a couple holes i'll send a prog thru the Rs232 to the machine as it so easy with speeds and feeds toolno.s and the basic prog layout.
    Only thing i do manually is squaring up blocks with face mill!
    Cheers Kev :cheers:
  1. Minimum system requirements
    By thedoctor in forum SheetCam
    Last Post: 10-17-2008, 09:16 AM
  2. Laptop System requirements
    By cncuser1 in forum Solidworks
    Last Post: 09-11-2008, 12:20 AM
  3. Minimum System requirements?
    By bcnc in forum Mach Mill
    Last Post: 03-02-2008, 11:53 PM
  4. Minimum PC system requirements please?
    By Oldmanandhistoy in forum Mach Software (ArtSoft software)
    Last Post: 07-17-2006, 02:47 AM
  5. PC Requirements
    By Cyclone in forum Computers / Desktops / Networking
    Last Post: 04-19-2005, 02:57 PM
