603,939 active members*
1,846 visitors online*
    Jun 2016
    XYZ-Tech CNC Router Structure
    Hey everyone, I've been planning a CNC Router Build but I just found a 3 year old 24"x48" XYZ-Tech CNC Router locally. I've read mixed reviews on here about these machines but most of the negatives seem to be around the electronics and packaging. I'm primarily concerned with the construction and rigidity of the structure. The machine is cheap enough that I can replace most of the other components. The hardest part of this build would have been the frame so this would be really convenient. The hardest thing I would be cutting is Aluminum. Thanks for the help.
    Jun 2016
    Re: XYZ-Tech CNC Router Structure
    Bump
  1. CNC Router - Frame Structure
    By gmoreno_cnc in forum Uncategorised WoodWorking Machines
    Last Post: 05-02-2020, 12:49 PM
  2. Disassembled structure for cnc router
    By linda_roctech in forum Roctech CNC Routers
    Last Post: 12-29-2014, 08:56 AM
  3. WOOD CNC ROUTER structure
    By Morntech2008 in forum OneCNC
    Last Post: 11-21-2014, 10:59 AM
  4. new ATC CNC Router with outstanding structure
    By limacchina in forum News Announcements
    Last Post: 02-16-2011, 09:12 AM
  5. Router Structure
    By One of Many in forum DIY CNC Router Table Machines
    Last Post: 01-29-2007, 04:08 PM
