Z axis
Z axis
XZero cnc
Z
XZero cnc
8 inch SQ rail , profile rails
XZero cnc
SQ Z
XZero cnc
Nice, what size rails?
Brian P.
8 inch 20mm rail
XZero cnc
The 5 and 8 inch z both of those are 16mm Thomson rails, only have in 8 inch with 20mm round rails
XZero cnc
Like all parts on machine , all mating parts are machined flat
XZero cnc
12mm NPN prox switch for all Z axis , except 20mm 8 inch round rail
XZero cnc
Usb controller 3 axis and 4 axis, in photo 3 axis . they work very good
XZero cnc
Wireless hand control for mach3 , people that have them say they are great
XZero cnc
XZero cnc
Here is some home made bellows to cover rails and ballscrew
Frank's Workshop
XZero cnc
Hi George, Check out this link which has bellows. You could get them to make custom lenths/sizes to suit your line of machines.
Hebei Shengtuo Machine Tool Accessories Producing Co., Ltd. - Plastic cable drag chain, steel cable drag chain, mounts
Or just go to alibaba and type in cnc bellows cover which will bring up many suppliers.
oooh, i lke those. how much travel do they eat up?
I did see that stuff, i get cable chain from them. on a 24 inch you will lose 1 1/2 inch travel each side with bellows. As long as you never over grease the rails the dust will never do damage. Only the ballnut might become a problem with dust. some have plug up . but you can easily clean the ballnut out. Round rails also never have to worry about dust
XZero cnc
The ballnut ,you can take off wiper and soak in WD40 or spray , with ballnut still on ballscrew . the only ballscrew that have had some problems is the Z axis ballscrew. But easy to remove and clean .
XZero cnc
Here is the brackets for mounting the prox switch on long axis
XZero cnc
Easy mounting
XZero cnc
I should have today the Y angles ready for all machines to mount cable chain and 2 prox switches , all bolt on
XZero cnc
