George: I sent you e-mails are you receiving them?
John:stickpoke
gio666, how much flex in the x=60", is this why your are trying new mount method? Is there anything preventing you from sistering (double up) an additional x beam on each side?
The change was for the M5 bolts , there was not enough thread and was pulling out easy if tighten to much , in the 1/8 3/4 steel , so drill out steel and and used t-nuts behind,
XZero cnc
sounds like you needed more and better material for tightening, good. where is the 1/8 x 3/4 steel plate position, I am not getting it, photo maybe? Thanks Rob
before he was bolting into the 1/8" plate, but it was poving not very strong threads.
now it uses the plate for support only. behind the plate is a t nut which accepts the bolt and is much stronger. with the t nuts alone, they crush the aluminium which is not good. think of the 1/8" plate as a big long washer.
theres a picture posted already, but its hard to figure out what it is i guess.
got it!
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/ISHJh8lBpAM?hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/ISHJh8lBpAM?hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
[nomedia="http://www.youtube.com/watch?v=ISHJh8lBpAM"]YouTube- XZeroCNC.mp4[/nomedia]
XZero cnc
Raptor 24x36 900 IPM Y axis . 700 IPM X axis
[nomedia="http://www.youtube.com/watch?v=gJ3mPKgSVow"]YouTube- XZero CNC Raptor[/nomedia]
XZero cnc
Goerge: Are you going to ship my machine tomorrow.
Sorry to post here, but my e-mails don't seem to be getting to you.
i replied to you about 5 mins ago?
XZero cnc
