Originally Posted by
Carltech
Okay I will have another look, I didnt realize I could highlight the text and copy it to Google translate. It doesn't have the pictures though but I have done some more research elsewhere and found a diagram that seems similar. What I am getting confused with is the optional and suggested things, like:
adjustable decay
voltage level - i suppose I will need a volt meter to adjust it to the correct voltage of ?v
enable pin should be shorted to ground
I stopped by an electronics store and got a roll of 20ga 4 channel wire which I hope will be good for this application and 16ga for the power.
