What model are the higher uprights for?
Here is a little info on Artcam
ArtCAM Express 2011 - Design
ArtCAM Express 2011 - Machining
Gallery
Customise Express
XZero cnc
Those higher uprights are for the first design of the Raptor machines,and will only be made one time on those,the new design Raptor is a completely different design and will have those for the new design Raptor soon,just have so many new parts being made it might be a little while yet before i get to those ones ,
XZero cnc
Had to change the logo on the stand corners ,and will have them done by Wednesday , also now have center leg to for support for the longer tables ,
XZero cnc
Will have BLDC motors kits with encoders for sale in 2 weeks ,in nema23 and nema34
XZero cnc
Here is a forum ,and trial download
ArtCAM Express 2011 Free Trial Software Download
ArtCAM Forum • Index page
XZero cnc
The business model for Artcam Express is based on selling the plugins. Express itself is pretty stripped down so make sure that it will do all you need it to otherwise it won't take long before you have spent more than VCarve Pro and even Aspire. Someone calculated in another thread that Express with all the plugins can run to about $3500...
This isn't to disparage the product since is has a great pedigree and if it meets your needs without plugins it is a steal. The plugin approach is nice since it allows you to tailor the product to your needs or work up to a full set of capabilities as needed.
bob
Hello Dave: Just an update on my problem. I finished a 9 plus hour project late last evening and everything went perfectly. I guess I was being to cautious not to strip the threads in the aluminum spider coupling. While the Z axis was the only one slipping, I went back and checked the others and gave them an extra bit of grip as well. Thanks again for your help.
John
. Powder coated blue top cover and silver case and front. Machined aluminum handles/switch guards
Size is 18” wide x 14” deep and 4” thick.
Computer mother board and power supply
Front has rotary on/off switch, green status light and E-Stop button.
Side mounted blue light fans with integrated grills
On the back are cut outs for G540, power plug and auxiliary outputs. Hone limit switch input cut-outs below G540
XZero cnc
Have made a couple changes on the ViperXZ
30x36 30x48
now will have the 4080 or 8080 profile ,option for 1610 and 2010 ,also has the 25mm Thomson 60 Case rails
ViperX2
40x48 40x60
all 3/4 inch aluminum frame
option 1610 and 2010 and 2510 for 40x60
30mm Thomson 60 Case rails
changes to the 8 inch round rail Z axis ,there is now more mounting holes for adjustment to where you would like to have the Z axis fit
XZero cnc
Whats the status on the bosch colt mounts..does the guy have them machined properly now?
no, there is a notch for the spindle lock button. if youy use that notch and line up the button, the cord hits the Z saddle. if you rotate the colt a little its fine, and there is still perfect access to the button.
so basically, they are fine as is, although i may modify them next run.
How about a xzero mach3 screen set to go with that new Xtreme :cheers:
Sily question but how is this possible?
In post#1477 the text from airbrush reads:
"George said the guy had forgotten to machine a notch in one spot."
Yet in post #1478 the text from ihavenofish reads:
"George said the guy had forgotten to machine a notch for the cord."
How can the text change from "in one spot" to "for the cord" ???
