587,772 active members*
2,933 visitors online*
Results 1 to 1 of 1
    Apr 2015
    130
    Y Axis Bearing Spacing
    I'm starting my first CNC Build. I'm using SBR-20 1000mm (39 3/8") rails for my Y Axis spaced approx. 10". My Z Axis has 7" of travel & the back plate is 4" wide. I plan on fabricating 1/2" thick alum plates to mount the bearings to the back plate. How far apart should I mount the bearings for good rigidity and still maintain maximum travel? Are there any spreadsheets available to help calculate this distance? This will be a moving gantry machine.
  1. 5 X 3 router Need input on bearing spacing
    By whimsical in forum DIY CNC Router Table Machines
    Last Post: 02-08-2015, 10:42 PM
  2. Y-Axis / Z-Axis Bearing Setup Question
    By KittyPants in forum DIY CNC Router Table Machines
    Last Post: 08-22-2013, 10:45 AM
  3. bearing spacing ?
    By TrickyCNC in forum DIY CNC Router Table Machines
    Last Post: 02-23-2012, 12:35 AM
  4. Angular Contact Bearing Spacing?
    By ngr1 in forum Benchtop Machines
    Last Post: 12-21-2006, 01:44 AM
  5. Linear bearing spacing & Sizing linear rails?
    By fyffe555 in forum DIY CNC Router Table Machines
    Last Post: 12-07-2004, 08:09 PM
