603,407 active members*
2,401 visitors online*
    Feb 2013
    Y axis issues.
    CNC 3040Z
    A new member of the chinese machine club.
    My Y axis is getting off, it moves toward the spindle side as it cuts.
    ie: when cutting a pocket it leaves steps on the back side and removes
    more and more material from the front. The x and z axis is dead perfect.
    I have used a indicator to check y movement and it's dead on.
    Also when I first got the machine, I noticed the steppers where fairly hard
    to turn with the controller on and now they are easily moved (all steppers).
    Is this normal?
    If I wanted to replace the drivers, how do I order the correct ones.
    Thank You,
    Bo Hunter
    Sep 2006
    6463
    Hi, have a browse on Utube.....there are a number of vids on these cheap Routers and all state that they have issues with the X axis (cross beam) moving or slewing when milling to one side of centre......the build is alluminium and not all that strong.
    Ian.
    hello ,Bo Hunter, check and tighten every electrical connection and nuts bolt you can find , also check the belt ,maybe the belt is loose cause the working size not accuray .
  1. G540 Mach3 Display Issues & Slave Axis Issues
    By umustsurf in forum Gecko Drives
    Last Post: 09-30-2011, 03:23 AM
  2. 4th axis issues
    By two4tom in forum Tormach Personal CNC Mill
    Last Post: 04-15-2011, 11:43 AM
  3. more 4 axis issues
    By brokenrinker in forum Mastercam
    Last Post: 01-17-2009, 06:13 PM
  4. 4th axis issues
    By capital in forum Fanuc
    Last Post: 01-16-2009, 02:07 PM
  5. Issues with Y axis
    By Projex in forum Tormach Personal CNC Mill
    Last Post: 12-17-2008, 01:04 AM
