587,822 active members*
3,009 visitors online*
Results 1 to 4 of 4
    Jul 2016
    6
    "Y" axis problems, need help
    I am new here and need some help. My maintenance guy is looking to correct my "Y" axis location problem (.005/.006) repeatability.
    Axis will repeat when coming from the same direction, off when from other direction.
    1997 EzTrak DX This machine has been great over the years.
    Thanks for any help
    I have jobs falling behind
    Thanks Charley
    Jun 2007
    129
    Re: "Y" axis problems, need help
    My guess is a mechanical problem. Check for any movement in the y axis control wheel when powered up. Also let us know what you have found wrong.
    Jul 2016
    6
    Thanks for the suggestion, That does not seem to be the problem-No movement slop in hand wheel or readout movement when powered.
    When using manual the readout and dial indicator repeat from both directions. I can also pull and push on the table in the "Y" and only move the indicator < .001 total.
    Tanks again, Will post when problem is found and corrected.
    Quote Originally Posted by reabdet21 View Post
    Jul 2016
    6
    Thanks for those that gave advice. Problem was "Y" motor. Replaced and back to normal.
  1. Common Laser Problems and Solutions(1) - Y Axis movement issue on "Test"
    By Gweikelasers in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-22-2016, 10:45 PM
  2. Bridgeport Series 1 R2E4 "Y" axis problems
    By Kevin45 in forum Bridgeport / Hardinge Mills
    Last Post: 09-11-2014, 08:24 PM
  3. Replies: 17
    Last Post: 02-22-2014, 06:58 PM
  4. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  5. Kitamura Mycenter3 "Z" axis problems
    By bluechip9 in forum Kitamura
    Last Post: 05-06-2012, 05:54 PM
