587,283 active members*
5,197 visitors online*
Results 1 to 9 of 9
    Sep 2008
    10
    Y-axis servo motor blowing fuses
    Machine is a Bridgeport Interact 1 Mk2.
    Have Installed replacement Y-axis servo motor which I believe is wired correctly but upon powering up the machine and pressing the orange power button, the Large fuse (MF1) blows instantly. The trip switch for the 3 phase plug point goes also.
    Would incorrect wiring cause this or is there something inside the motor shorting maybe?
    Any help appreciated, more info available if required.
    Many thanks
    Dec 2003
    24223
    Try with the motor disconnected, If they still blow it is probably not the motor.
    Al.
    Albert E.
    Sep 2008
    10
    With motor disconnected the fuse doesn't blow, so pretty sure the motor is at fault. Any advice on the best people to deal with for replacement / recon SEM axis motor units? (UK based ideally)
    Cheers.
    Nov 2004
    3028
    Clarkson
    Near Chicago
    George
    Sep 2008
    10
    Thanks George but unfortunately we are in UK )
    Dec 2003
    24223
    SEM is, or was a UK company.
    Either partially dismantle the motor and check the condition of the brushes and commutator and colouration of the windings to see if there is anything obvious that can be fixed, the alternative may be to take it to a motor rebuilder and get them to check it out.
    If you opt to repair it yourself, it can be tested on an automotive battery before putting back in place.
    Al.
    Albert E.
    Nov 2006
    925
    Mike at machinesupportservices.com in Crewe or thereabouts should have something.
    Do you know how to use a meter? Could talk you through testing it.
    Mark.
    Nov 2004
    3028
    SEM is Small Electric Motors of the UK.
    Google and see what comes up on that side of the pond.
    Pull out a brush and give it a sniff test. If it smells burnt, it probably is.
    George
    Nov 2006
    925
  1. Blowing Z axis fuses on 6MB
    By moldmker in forum Fanuc
    Last Post: 08-30-2008, 05:34 AM
  2. X-Axis Blowing fuses
    By Thom45 in forum Commercial CNC Wood Routers
    Last Post: 02-21-2007, 08:33 PM
  3. Blowing fuses
    By kaderick in forum CNC Machine Related Electronics
    Last Post: 12-05-2006, 06:34 PM
  4. Blowing the fuses
    By rocks101 in forum Hobbycnc (Products)
    Last Post: 02-26-2005, 10:00 AM
  5. Motor tuning and Blowing fuses
    By DAB_Design in forum Gecko Drives
    Last Post: 11-02-2004, 02:10 AM
