I have a JoesCNC 2006 that is having a shaking problem only in the y-axis.
Here are some pictures to show you what is going on:
The blue on on the left was cut at 120ipm, the red on the right at 50ipm.
Ger21, has given me many suggestions but they have not panned out.
I have also added the moving knot cable system that did help a little.
The biggest thing I notice, is the x-axis moves with almost no noise, while the y-axis rumbles as it moves at speed. This happens weather cutting or just making free air moves.
Things I have tried with no luck:
1. Microstepping 1/2 1/4 and 1/16.
2. Various amounts of tension on the y-axis bearing/rail assembly.
3. Various amounts of tension on the y-axis 5-start acme screw.
4. sanded the rails smooth, they are galvanized.
5. added threaded rod and square tubing to the sides of the gantry, it is very stiff now. with extra rod just below the x-axis carriage in the middle of the gantry sides.
6. carefully cleaned the y-axis bearings.
7. Various bits, up/down cut 2flute qaurter inch, v-bits.
8. moved x-axis stepper motor to y-axsi position, no change.
9. rattler style damper on the y-axis no change. (Works great on z went from 40ipm to 80ipm)
Please help, I can see many videos of JoesCNC2006 models cutting at 100-150ipm on youtube, but mine cannot give me a decent quality. Only thing I have been able to do is roughing passes at 120ipm then a finish pass at 50ipm. But this of course slows things down.
