588,232 active members*
4,448 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Yaskawa LX3 servopack alarm
Results 1 to 8 of 8
    Jan 2007
    24
    My friend has HitachiSeiki HT20 CNC Lathe with Yaskawa LX3 controller.
    Machine is working just fine when rapid selection is at 25%, but if
    we try to run it at 100% rapid it gives us following alarms:
    390 Servopack alarm
    391 Servopack alarm
    310 servo off
    Any help will be appreciated.
    Thank you
    Jun 2008
    1104
    What alarm code does it give on the drive itself?
    Jan 2007
    24
    servopack alarm
    I think it is number 4.
    Jun 2008
    1104
    Overvoltage. Probably on the DC bus inside the drive. You may get round this by replacing either a transistor and/or a resistor on the braking circuit.
    Jan 2007
    24
    servopack alarm
    Thank you for your help.
    If i post a picture of a servopack, would you be able to point me to right direction where to look for that transistor or resistor?
    Sep 2008
    19
    hi crocnc,
    not real sure where to get the transistors or resistors, but thought I would mention that a guy i know recently got a brand new retrofit drive from Yaskawa that replaced the old SR drives on the Hitachis that he installed himself. He said they called it a Type II. may be worth checking out.
    Jan 2007
    24
    servo alarm #4
    Can you provide any more information about this retrofit?
    Does anybody knows if i can run Hitachi HT20 lathe with PC and Mach3?
    How to make connections if it is possible?
    Sep 2008
    19
    From what I understand it is a new style servopack with the same wiring connections and mounts up exactly the same. The guy I know was told that it was built with parts readily available today so repair and replacement is much easier. I'd call yaskawa for more details since I've only heard about it.
    Hope this helps.
  1. Yaskawa servo
    By rai in forum Servo Motors / Drives
    Last Post: 04-28-2009, 04:32 AM
  2. Yaskawa and EMC2
    By jdr in forum LinuxCNC (formerly EMC2)
    Last Post: 03-06-2008, 10:01 PM
  3. Yaskawa help please
    By Arty 3000 in forum Stepper Motors / Drives
    Last Post: 02-20-2007, 05:35 PM
  4. yaskawa help please
    By h_2_o in forum Servo Motors / Drives
    Last Post: 11-20-2006, 02:01 AM
  5. Yaskawa & Galil DMC 730
    By ChiTownTech in forum Linear and Rotary Motion
    Last Post: 11-07-2006, 04:41 AM
