588,457 active members*
5,070 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Yaskawa servo with Syntec controller 0.4 mm error cutting
Hybrid View
    Jun 2010
    10
    I have a CNC Router with Syntec EZ4 control, Yaskawa SGDM-10ADA-V servo drives and Yaskawa SGMGH-09ACA61 servo motors.
    When I ask to cut a 20.8mm pocket the result is a 20.4mm pocket, I have checked in the X axe, so I have an error of 0.4 mm, a lot.
    I´m not shure if this is a machine mechanical issue or a bad servo-controller configuration, which I prefer to think
    Could that parameter "Position servo mode(0:CW;1:Volt;2:AB)" in the Syntec controller, be the reason?, mine is set to "2"
    http://i2.photobucket.com/albums/y27...DEADC347BC.jpg
    http://i2.photobucket.com/albums/y27...DECEAF4940.jpg
    Could anyone help me with that?
    Kind regards.
    nachin11
    Oct 2008
    16
    Hi, not sure if you are still having this problem?
    If it is in the X Axis, have you tried changing parameter (141 X Axis Pitch amount)
  1. Excitech CNC - Syntec Controller Users
    By BC-CNC in forum Chinese Machines
    Last Post: 01-11-2020, 10:38 AM
  2. Syntec Controller and Network Access
    By nash in forum Chinese Machines
    Last Post: 11-14-2019, 10:35 AM
  3. YASKAWA ERROR 393 SERVO PACK (Z)
    By Northeastguy in forum Servo Motors / Drives
    Last Post: 06-08-2012, 05:11 PM
  4. Who has syntec controller running there chinese atc
    By simso in forum Chinese Machines
    Last Post: 10-22-2011, 02:47 PM
