588,484 active members*
4,947 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Yaskawa SGDH and SGDA servo motor/drive wiring questions
Page 5 of 5 345
Results 81 to 82 of 82
  1. #81
    Jun 2015
    6
    Re: Yaskawa SGDH and SGDA servo motor/drive wiring questions
    Hi there.
    I agree that it works at 24v but with 5v it also works,
    I have wired as you indicate, but it still does not work.
    I have wired 47 to +24, 40 to 0 (the servo is activated and prepares to turn), if I now connect terminals 5 and 6, at a voltage of 0-10v, the motor does not turn. After I connect the terminal 42 to 0v, the motor starts to turn, correct it works in the servo screen write ". =. = Not". But now I disconnect terminal 42, the motor stops, and now I connect terminal 43 to 0v and the motor does not turn.
    the problem is:
    signs 42 and 43 are "do not allow something" that is:
    the servo is waiting for a current in negative 5 and 6 to turn backwards
    Gracias
  2. #82
    Jan 2005
    15362
    Quote Originally Posted by caripen View Post
    See if you can use the Step /Dir to change the direction , and the voltage for the speed control would stay the same 0-10v
    Here is how you would do it with changing the power source +/- Ground stays the same, you would just switch between the +/- voltage from the power supply
    Mactec54
Page 5 of 5 345
  1. Kflop/Kanalog Wiring for Yaskawa SGDH drives
    By upsyd0wn in forum Dynomotion/Kflop/Kanalog
    Last Post: 07-25-2014, 12:39 AM
  2. Yaskawa SGM-A5Aw 12 bit absolute encoder with SGDA drive
    By kmarsus in forum Servo Motors / Drives
    Last Post: 03-14-2014, 05:43 PM
  3. Yaskawa SGDH drive (custom model Y49)
    By bouseman in forum Servo Motors / Drives
    Last Post: 09-19-2010, 10:35 PM
  4. Help with Yaskawa SGDA-04AS drive ...
    By katran in forum Servo Motors / Drives
    Last Post: 06-26-2010, 12:39 AM
  5. yaskawa SGDA-08AS SERVO DRIVES
    By blackbeard52 in forum Servo Drives
    Last Post: 07-08-2008, 02:07 PM
