587,166 active members*
3,498 visitors online*
    May 2009
    63
    Yasnac programming set/up
    I am working on a mori sl-2 with a yasnac 200g single line controller. I have a bunch of old programs that are still used, but the person who knew how to set-up the machines has left the company. My question is with the following program if i can get a walk thru for setting tool offsets I would appericiate it.
    Set up sheet info:
    X dia. setting 60000
    Z setting 61250
    T2 x-60000
    z 15000
    tool stick out 2.6250
    now the program (tool is a spot drill)
    N2 G50X-60000Z15000S1000
    G00T0202
    G97S110M3
    G0X0Z1000M08
    Z100
    G1Z-200F30
    G00Z10000
    X-60000Z15000
    T0200
    M30
    N1000G00T0816
    M30
    Just to get the machine running I have been using the x,z "offset" position in the g50 block, and the g00 return block, apparently it was done differently with machine lock in the past. Just trying to figure it out. Any help would be appericiated.
    Mark
    Apr 2010
    38
    Give me a call it is easier.
    413-329-1503
    Mark Reuss
    May 2009
    63
    Thanks I'll give you a call later today.
  1. yasnac mx1 on matsuura programming help needed
    By Brian FRF in forum G-Code Programing
    Last Post: 07-29-2015, 03:09 AM
  2. yasnac mx1 on matsuura programming help needed
    By Brian FRF in forum Uncategorised MetalWorking Machines
    Last Post: 08-04-2009, 07:57 PM
  3. Yasnac mx1 vs. mx5
    Last Post: 06-10-2009, 05:32 AM
  4. how to dnc a yasnac mx1
    By matosjulio in forum G-Code Programing
    Last Post: 02-06-2009, 10:26 PM
  5. yasnac J 100 M
    By Furlan in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 11-17-2007, 04:55 PM
