Total newbie. Just got a set of 4030s, C10BOB and 36v PSU.
I wired it up to test with 1 stepper, and am not able to jog from mach3.
The motor is locked when power is on, so I'm assuming it's powered up properly. I set up mach3 pins as per the keling webpage, but I get no motion on jog.
Is there any way to hook up a volt meter to test if it's the C10 BOB, the parallel cable, or the mach3 setup?
-Tom
