603,807 active members*
4,398 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > Yet another Hardinge Accuslide
Results 1 to 4 of 4
    Jan 2012
    48
    I recently picked up a Hardinge AHC that's been fitted with an Accuslide. The parameters were lost when the batteries died, the spindle encoder is bad and the VFD is DOA. Good candidate for a retrofit 8-) .
    These pictures are at the shop where I got it. My quarters are too cramped to get a good full on shot. Some parts have already showed up so hopefully progress will be quick.
    Got the acorn up and ran through the initial setup. Also the motors/drives and did the initial tune on them also.
    Jan 2012
    48
    Re: Yet another Hardinge Accuslide
    I got the computer mount moved back to give me a little more room to move around.
    The box is cleaned out.
    New face plate made and mounted. There will be another over this one for the monitor. I plan to mount the drives to the back of this plate.
    Attachment 453552
    Attachment 453554
    Attachment 453556
    Jan 2012
    48
    Little more progress yesterday.
    Drives mounted
    Monitor mounted to faceplate and then mounted to the box
    Made a small bracket to hold the computer and USB ports - trying not to penetrate the outer shell if I can avoid it.
    Attachment 453630
    Attachment 453632
    Attachment 453634
    Jan 2012
    48
    Got a little more done in both cabinets. Still need to do some wire management but lights are coming on and flashy things are flashing!
    Attachment 454252
    Attachment 454254
    Attachment 454256
  1. Accuslide Hardinge CNC retrofit problems
    By num1bryanp in forum Fagor Automation
    Last Post: 03-03-2022, 05:23 PM
  2. Hardinge Accuslide CNC Lathe Control Retrofit
    By slodat in forum Hardinge Lathes
    Last Post: 05-24-2021, 03:25 AM
  3. new guy with an accuslide
    By nismopu in forum Hardinge Lathes
    Last Post: 11-08-2020, 05:50 AM
  4. Replies: 2
    Last Post: 05-05-2015, 07:53 PM
  5. Fagor Accuslide retrofit
    By Captdave in forum Fagor Automation
    Last Post: 02-18-2009, 04:59 PM
