Hi folks,
I have no clue what is going on but I did some successful cuts with the machine at the beginning (begginers' luck?). I use linuxcnc and parallel port and I started to have errors in my cuts. I realized the problem was not skipped steps but x-axis motor to stop working for a few seconds every now and then.
After checking all sort of details with the computer and configuration (elongating step pulses and other different ideas I picked up here) I was not able to stop that behavior, so I thought it might be a thermal problem: maybe x-axis driver was overheating and entering on some form of thermal shutdown. I opened the box and changed the switches to the minimum current. it did not mattered!
I closed EMC2 program and I realized the x-axis motors that were holding position did stop holding position every now and then (I could notice a subtle noise every time energy stopped flowing through motor windings and when it was back). So that suggested me software was not to be blamed here.
Later, I powered off my computer and the problem of the motor stopping holding position was repeated every now and then (each minute or so for a few seconds). What the heck?
So I removed the parallel port cable from the computer and the problem disappeared: x-axis motor will hold position forever now.
Using a second computer (a different model) did not cause any trouble and the CNC machine worked happily and trouble-free then.
Of course I am going to keep the machine with this second computer but I am at a loss at what could have caused the above mentioned issue. (All devices are powered from the same power socket and ground connection).
Any ideas?
Thanks a lot!
