603,832 active members*
3,701 visitors online*
    Nov 2004
    Z axis backlash
    I just noticed that when I engage the fine adjust on the Z axis, the knob turns over one full turn before the head starts to move. I would like to get rid of this "slop". Does anyone have any ideas? I was thinking that I could put a shim behind the "rack" that is mounted on the column. This would move it out and make it tighter on the "pinion". Am I on the right track with this thought? And help would be great!
    Nov 2004
    The Update
    I put a .009 shim behind the rack and it helped a little. When I took the fine control off the machine, I found a worm and worm/gear setup. It seems that quite a bit of the slop is coming from this assembly. Is there a way to tighten this up?
    Feb 2004
    Sloppy Rack
    I too was trying to figure a good way to limit the slop in the rack. After reading a few other folks attempts at this i decided to scrap it all together. I removed the rack, gear, handle and fine adj. I then got on ebay and started looking to ball screws. I found a 14" ground with nut for something like 40 bucks. I then machined a couple bearing blocks mounted them to the side of the column and it it working very well. I am pleased with it. Now the Stepper is mounted on the top of them machine and not stichin out the front.
    Mike
  1. Ballscrew Basics
    By Swede in forum Linear and Rotary Motion
    Last Post: 06-25-2025, 03:36 PM
  2. 4020 4th axis problems
    By little bubba in forum Fadal
    Last Post: 06-14-2005, 03:08 AM
  3. Backlash with worm drives ?
    By andy_ck87028 in forum Mechanical Calculations/Engineering Design
    Last Post: 02-02-2005, 11:40 AM
  4. Backlash comp: does other axis pause during?
    By lesd in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-30-2004, 08:05 PM
  5. Z axis backlash adjustment help sieg x3
    By replicapro in forum Benchtop Machines
    Last Post: 11-07-2004, 07:13 PM
