588,166 active members*
4,517 visitors online*
Results 1 to 6 of 6
    Jan 2007
    61
    Z-Axis depth guide sensor ?
    No matter what I do, I can’t get my work area exact level enough to have the proper depth when milling my PCB on my DIY CNC machine, (I’m always cutting to deep some areas and to shallow others). always around 0.0050 off
    (I’m going to try routing the work area level again).
    However,
    Is there any general sensor method I could hookup that would act as a
    depth guide ?
    Example:
    If I mounted something similar to a spring loaded thin metal ball point pen
    To the base of my spindle, so that it would complete a circuit (similar to a touch off plate) When ever it touched the copper PCB, then I could use it as a depth guage to control How deep past the pen’s contact point I drilled.
    I would always adjust the Z position relative to the contact point of the pen.
    Has anyone done this ?
    Is there anything like this, How can I do it ?
    Thanks,
    Jul 2003
    1760
    How are you holding the circuit board down?
    sam
    Jan 2007
    61
    A vacuum table, Plus I have a 0.0060 deep aluminum rail system around
    the boundry with a small lip that overhangs the PCB about 1/32.
    I just slide the PCB into the pocket and turn the vacuum table on.
    It's verry flat, and stays in place, but the PCB is unlevel some how because
    of the workarea, It's MDF, I have 4 bolts on the edges that I use to adjust
    each cornner of the work area, I also have two bolts in the center that
    screw down and can actually pull the workarea down for fine adjustment.
    No matter what I do, I'm always off around 0.0050 across the 6x4inch PCB.
    and thas two much, some of my pcb stock is not even that thick !
    Jul 2003
    1760
    How are you facing the work area? If you machine it flat - then suck a vacumm - it isn't most likely going to be flat.
    My table is actually plywood - I machined it flat under vaccum then drilled the holes for the vacumm to come thru. That way - when vacumm is applied - the table is flat.
    My next table will probably be mdf. (bit more stable for me)
    http://www.electronicsam.com/images/KandT/vactop.JPG
    http://www.electronicsam.com/images/KandT/vacback.JPG
    Jul 2007
    any one can tell me about wcs in maastercam x complete video
    Jul 2007
    i am a beginner in cnc programming and masterrcam is there a good video that an explain 3d design and toolpath ,construction plane thruogh wcs yr response will be higly appreciated thanks
  1. Z axis depth not correct
    By jtriggs in forum Mach Mill
    Last Post: 12-27-2006, 06:52 AM
  2. non ARC height sensor
    By sunmix in forum CNC Machine Related Electronics
    Last Post: 11-05-2006, 06:51 PM
  3. Gantry on outside of y axis guide pipe
    By andydoc in forum Commercial CNC Wood Routers
    Last Post: 12-29-2005, 10:20 PM
  4. Help with Irda sensor on computer
    By jtree83 in forum Computers / Desktops / Networking
    Last Post: 04-18-2005, 03:35 AM
  5. Optical sensor...
    By aghobby in forum DIY CNC Router Table Machines
    Last Post: 09-08-2004, 05:17 PM
