Dear John and Gerry,
John You mention wipers. The bearings I have seem to have a hard rubber ring at each end. Are these wipers?.. or is something else needed.
Gerry Thanks for the encouragement. I did a trial with a jig fence and spacer. My wonky drill press tended to deflect towards the front as the forces from the Forstner bit (32mm dia") tilted the table out of right angle with the drill press column. I clamped a vertical strut down to the floor to support the front edge of the table and that improved things massively.
The sample bearing housings and shaft supports seem to be pretty good, and are in line. Anyway, it was obviously not a "bodge and filler evening"..
Best wishes to all,
Martin
