I"m running an aluminum job with a 1995 VF3 Haas.
When milling occasionally it will not go to the correct Z height. I 'm running 3 parts at a time for about 2 weeks on a fixture and everything was fine.
I 1st noticed it when form tapping about 1" deep when it messed up the top 1/8" of all the threads. I tried to work around by changing the R and Z values but I kept doing the same thing.
I have a set of operations where I am undercutting circles with a T slotter on the 3 parts one at a time. The 1st part comes out fine but the 2nd and 3rd the it cuts at the wrong level, and at the same place.
The day before the operator forgot to screw a SS Bolt down all the way and trashed the T Slotter insert. It cut into it with a G3 move, it did not come down on it in the Z direction.
Also it seems jumpy/jittery when STOPPING while moving down in the z axis both when moving manually and when it's running on it's own. Moving up it's fine.
I did replace the X and Y axis motor control card a couple of years ago but z axis card I believe is original.
Any help would be appreciated.
