588,591 active members*
10,770 visitors online*
Results 1 to 8 of 8
    Jun 2011
    55
    z axis raising during code
    Hello everyone i have a problem with my z axis raising while running code.
    I start with a -.005 depth of cut and when i am finished about an hour later i am about .003
    cant figure it out . I am using deskcnc controller.
    Aug 2011
    999
    Quote Originally Posted by mrlttlman View Post
    That is not a huge difference. Assuming you are not losing steps I would guess it is thermal expansion of the frame/gantry especially if this would be a larger aluminum machine.
    Jun 2011
    55
    i never thought of that. i lived with it for a while while cuting wood not noticable but when etching glass its really is especially when half of it never makes it on the glass (ha ha) any other possibilites?
    Jan 2012
    Bit getting pushed into the collet maybe?
    I would expect lost steps to work the other way: as it's more likely that steps get lost when lifting the weight of the router, it drifts lower as the job goes on.
    Aug 2011
    999
    Well, that was just a wild guess ande may be totally off but if you post a picture of your machine and more technical details I believe the swarm intelligence of this site will find an explanation for this phenomenon.
    Jun 2011
    55
    Lee
    i thought about theat too so i ran it in the air and took measurement afterwards and it was the same thing. Going to switch out the stepper in the morning with a bigger one.
    Apr 2005
    253
    try turning down your acceleration and retrying to see what happens.
    I'll get it finished sometime after I start it.....
    Jan 2012
    If you run the job multiple times, does it keep going up? Can you just run some "pogo-stick" g-code (bouncing the Z-axis full-travel up and down) and duplicate the results?
    I guess I'd try a little harder to determine a root cause before I started swapping parts out.
  1. Z AXIS raising up
    By i_am_joe in forum Uncategorised WoodWorking Machines
    Last Post: 04-27-2012, 10:51 PM
  2. Raising up a vise
    By webgeek in forum MetalWork Discussion
    Last Post: 11-08-2010, 03:49 AM
  3. Raising Voltage from 12 to 24v
    By Marcvw79 in forum Hobbycnc (Products)
    Last Post: 03-11-2008, 11:29 PM
  4. Techno-isel Z axis keeps raising at end of program
    By irishii75 in forum Techno CNC
    Last Post: 08-25-2007, 02:51 AM
  5. Keeping your zero when raising the head
    By wcarrothers1 in forum Benchtop Machines
    Last Post: 02-10-2007, 07:37 AM
