587,760 active members*
2,685 visitors online*
Results 1 to 5 of 5
    Aug 2015
    38
    Z Axis too hard?
    Hello all!
    I am in the final stages of building my Joe's and I am having a bit of a problem with the Z axis.
    When the Leadscrew is in place with the Lovejoy, spider and Stepper Lovejoy and I unscrew it, both the leadscrew and the coupling comes down.
    What can be causing the problem? Is it too hard? How do I unharden it? The bearings, leadscrew and stepper seem to be correctly aligned.
    I was thinking of puting a spring between the Lovejoy and the Bearing in order to keep it in place (see image below), but I dont know if that would be the correct solution to my problem.
    Would appreciate any help!
    Regards!
    Apr 2004
    5751
    Re: Z Axis too hard?
    The bearing should be keeping the leadscrew in place. If it's dropping, you might not have that bearing installed properly. I'm not sure what you mean by "hard", though - the hardness of the screw doesn't really have anything to do with whether it stays in position or not.
    Andrew Werby
    Website
    Aug 2015
    38
    Hey, thanks for the reply.
    By hard I mean that if I try to manually screw it when the Lovejoy coupling is in it's right position, then it feels hard and requires me to do some strenght.
    The Leadscrew remains in position when stationary, it doesn't drop. It comes down when I unscrew the Leadscrew.
    Apr 2004
    5751
    You talk about "screwing" and "unscrewing" the leadscrew. Does that mean you're rotating it clockwise and counterclockwise, or fastening the leadscrew assembly to your machine with other screws? A leadscrew should be fixed in place with the bearing so it can revolve in either direction without changing its position. The fact that it's difficult to turn means that it's probably mis-aligned, somewhere in the Z axis assembly. You need to sort out the alignment issues so the Z stage moves smoothly up and down without the leadscrew binding. Then you need to make sure your leadscrew is properly supported so it doesn't move when it turns.
    Andrew Werby
    Website
    Aug 2015
    38
    Thanks for the help awerby.
    I checked and there was a slight misalignment in the axis. I fixed it and also put a spring between the bearing and the coupling to prevent the screw from coming down.
    Regards!
  1. y axis hard when x axis locked (bf20 pm25mv/tm25v)
    By Redeeman in forum Benchtop Machines
    Last Post: 02-04-2016, 05:29 PM
  2. X axis hitting hard
    By BIG IGG in forum Tormach Personal CNC Mill
    Last Post: 04-29-2014, 02:05 PM
  3. How hard to build 3 axis Router.
    By preciseformwork in forum Maintenance DIY Discussion
    Last Post: 10-25-2010, 06:29 PM
  4. B-AXIS HARD OVERTRAVEL (+\-) IN MAKINO MC86
    By rajesh_1355 in forum Fanuc
    Last Post: 10-17-2008, 01:23 PM
  5. hard overtravel on all axis
    By stanman in forum Commercial CNC Wood Routers
    Last Post: 10-31-2006, 11:07 PM
