603,930 active members*
5,855 visitors online*
    Mar 2010
    Question Z.Bavelloni EGAR 320-4. PC->NC via com problem
    I am a machine operator for a Marble and Granite factory and have been working with an old Z.Bavelloni EGAR 320-4 and a new Breton nc260 k23.
    Recently the Bav has been having problems and the the controller Motherboard died and has been sent away twice for repairs with the last time replacing the mobo. it is the 1040 series.
    The problem that i face now is that i cannot get the pc and bav to communicate with each other, nothing has been changed on the pc end for sending the program code but i think the bav settings might have changed when the new mobo was installed therefore i matched the settings to the pc software. The PC software is easycad, egar320cam and for transfering to the machine is inout-cnc
    The settings are as follows;
    PC_________________________________
    Speed: 9600
    Bits no: 7
    Stop Bits: 1
    Parity: Even
    Port no: Com1
    Protocol: RTS
    Bav_________________________________
    Line Number: Line 0
    Standard: Rs323
    Input Speed: 9600
    Output Speed: 9600
    Number of Start Bits: 1
    Number of Data Bits: 8
    Number of Stop Bits: 1
    Parity: Even
    Protocol: none (Kermit or CMP)
    Flow Control: RTS/CTS
    Logical Name: COM1
    Ive been changing a few settings here and there trying to see what does what but nothing has worked, If i change the Bav line 0 to line 1 it wont even try to sync to receive the data, I have tried switching between the Serial and COM ports on the Controller. On the COM port the information will send from the pc end but does not show on the Bav end, and when plugged into the serial port it will not try to send from the pc.
    I also noticed when using software handshake XON/XOFF the pc will send the data still but the machine still does no receive it just stays in sync status.
    Any help will be much appreciated, otherwise this could be a long week
    If you need anymore info ask away.
    Cheers,
    Ben
    Re: Z.Bavelloni EGAR 320-4. PC->NC via com problem
    did you ever figure it out?
  1. Replies: 5
    Last Post: 01-17-2022, 05:47 PM
  2. z Bavelloni egar 323-5n
    By KIRILL33 in forum DNC Problems and Solutions
    Last Post: 10-31-2013, 03:10 PM
  3. z bavelloni egar 320
    By tsjim in forum Glass, Plastic and Stone
    Last Post: 09-26-2011, 02:44 PM
  4. EGAR 320 trouble
    By burik in forum Glass, Plastic and Stone
    Last Post: 12-15-2008, 11:42 AM
  5. Some n00b Egar 315 questions
    By Stonecutter in forum Glass, Plastic and Stone
    Last Post: 10-26-2008, 09:38 AM
