603,893 active members*
4,463 visitors online*
Results 1 to 9 of 9
    Jul 2008
    138
    Z load at 60% idle
    I haven't restarted my machine yet, but I thought I would ask here first.
    My machine isn't even running, but my Z load is at 60%. Any ideas?
    Thanks,
    May 2004
    4519
    Counterbalance problems?
    Feb 2010
    1184
    Quote Originally Posted by dfearnow View Post
    Thanks,
    What machine?
    How old?
    Counter Balance? Weight or Nitrogen?
    Servo Brake?
    Jul 2008
    138
    06 vf-2 ss
    weight c balance
    Feb 2010
    1184
    06 vf-2 ss
    weight c balance
    If you have a SS machine, then you do NOT have any counter balance. Rather you have a servo brake.
    60% is normal because the motor is holding the position.
    Rest easy and run it.
    Jul 2008
    138
    I could almost promise, Ive never noticed it before.
    But one of our guys looked it up and he got the same answer.
    So i guess Ill just ignore it.
    Thanks guys.:cheers:
    Jul 2005
    12177
    Here is an experiment for you to try.
    With the spindle stopped and well clear of anything make a note of the Z position then push Estop. The Z axis may drop slightly when you do this with slightly being anything up to 0.2".
    Like Haastec says the machine has a servo brake but the brake is only ON when the servo power is OFF. Estop turns the servo power OFF but sometimes the brake does not come ON quickly enough to stop the head dropping slightly.
    Jan 2007
    1389
    Quote Originally Posted by Geof View Post
    Geoff
    if I remember correctly that year and up to 2009 10 had a option so the head doesnt move at all. when power is off or a power failure. I have that option and didnt know what it was until it was explained to me.
    fake edit
    my ss runs 38% or less I beleive in the "Z" I can double check tomorrow if need be
    Mar 2008
    638
    Our VF-2ss is 64% at rest. Our VM-2 is at 35%
  1. drives go into fault during idle.
    By najnielkp in forum Viper Servo drives
    Last Post: 06-19-2012, 02:09 AM
  2. Idle Current Reduction
    By BOBINETTE in forum Hobbycnc (Products)
    Last Post: 07-29-2011, 07:33 PM
  3. Idle machines
    By MTSS Service in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-08-2009, 06:33 PM
  4. Idle Spindles
    By myouden in forum Employment Opportunity
    Last Post: 10-23-2008, 02:59 PM
  5. Motor screams and gets hot while idle
    By methuso in forum Hobbycnc (Products)
    Last Post: 05-14-2008, 06:52 AM
