588,127 active members*
5,293 visitors online*
Results 1 to 4 of 4
    Question Z Plate/Mount Length
    For my home build I'm planning on 8" of travel. I was planing on using a 1/2" aluminum plate for the moving part of the Z Axis, mounted to 4 HWIN 15mm bearing blocks. So the router bit to the first being block pair is about 8.5"
    How narrow, width of plate without a gusset, can I get away with assuming nothing more than a 1/2 "deep cut in plywood or MDF?
    May 2005
    3920
    Re: Z Plate/Mount Length
    The width will not have as big of an impact as a change in thickness.
    You didn’t mention anything else about the machine so one would be guessing. However when considering this plate the important thing is to make sure it is wide enough to mount the router / spindle. Balance this with the fact that excessive width impacts machine capacity.
    Jun 2005
    21
    When I built mine, I put the rails on the moving part and the blocks on the stationary part so there is more support and rigidity when the spindle is at the top of travel.
    Quote Originally Posted by lucky phil View Post
    Do you have any issue with sawdust buildup on the bearing rails?
  1. Spindle mount mounting plate
    By Farquarl in forum Chinese Machines
    Last Post: 10-30-2017, 06:26 PM
  2. Y - axis drive plate and NEMA 34 motor mount
    By 1Jumper10 in forum North America RFQ's
    Last Post: 05-12-2017, 04:54 PM
  3. Mosin Nagant Full-Length Picatinny Rail Scope Mount
    By velocitycnc in forum For Sale Only
    Last Post: 05-30-2014, 10:25 AM
  4. plate to mount CandCNC DTHC
    By johndjmix in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 05-03-2012, 04:34 PM
  5. Replies: 2
    Last Post: 07-18-2011, 10:19 PM
