603,967 active members*
2,379 visitors online*
    Aug 2013
    Z zero, error in script
    I have a problem with the "HiddenScript.m1s" script from the "auto tool zero" button .
    CurrentFeed = 50
    PlateThickness = 1
    ProbeFeed = 50
    Code "G90 F" &ProbeFeed
    If GetOemLed (825)=0 Then
    Code "G4 P5"
    Code "G31Z-5 F" &ProbeFeed
    While IsMoving()
    Wend
    Code "G4 P0.25"
    ZProbePos = GetVar(2002)
    Code "G0 Z" &ZProbePos
    While IsMoving()
    Wend
    Call SetDro ( PlateThickness)
    Code "G4 P0.5"
    Code "G0 Z2.0"
    Code "(Z axis is now zeroed)"
    Code "F" &CurrentFeed
    Else
    Code "(Z-Plate is grounded, check connection and try again)"
    Exit Sub
    End If
    Wen I run this script from "Auto tool zero" button in the "Mach3 VB ScriptEditor "
    I get this error "Error on line: 11 - Internal error<Code>.
    I have tryed many things, but only wen I remove Z-5 its getting through.
    Plz help my !!
    Stef
    Mar 2003
    35494
    This line is wrong, there should be a DRO number in there.
    Try this code:
    CurrentFeed = 50
    PlateThickness = 1
    ProbeFeed = 50
    Code "G90"
    If Not GetOemLed(825) Then
    Code "G4 P5"
    While IsMoving()
    Wend
    Code "G4 P0.25"
    While IsMoving()
    Wend
    SetDro(2, PlateThickness)
    Code "G4 P0.5"
    Code "G0 Z2.0"
    Else
    Exit Sub
    End If
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. Script Error since 996
    By velocityxlrg in forum BobCad-Cam
    Last Post: 06-12-2013, 05:56 PM
  2. Run G-code from script
    By leif_brunosson in forum LinuxCNC (formerly EMC2)
    Last Post: 11-11-2008, 08:39 PM
  3. VB6,VB.net,VB script,What one???
    By hydrospin01 in forum Visual Basic
    Last Post: 05-25-2008, 02:09 AM
  4. Macro/script-can this be done?
    By Splint in forum Rhino 3D
    Last Post: 02-13-2006, 04:50 AM
