Hello
I have a problem with the Read/Punch interface, when emergency stop is active.
When the emergency stop is not active and the edit mode is active i can transfer for example the parameter on the Flashcard.
When the emergency stop is acive and I try to write the parameters on the flashcard, the filesize is 0kb and blank.
I know that the read/punch process can cancelled by the reset button.
In emergency stop F001.1 is True.
G008.7, G008.6, F000.0, F006.1 are all false.
C-Executer and Macro executer are closed.
I hope someone have a solution.
Thanks Simon
