587,112 active members*
3,306 visitors online*
Thread: 0V WIRE
Results 1 to 5 of 5
    Jan 2011
    28
    0V WIRE
    I'm not sure if this is the right place to ask this question, but on a Fanuc control what does the 0V side do, it's usually tied in with the 24V. I have been having problems with a turret count proximity switch on a Citizens F-16.
    With the 0v wire disconnected (also has 24V and output wire) I get a signal from the switch, and with it connected I get nothing. Either way it doesn't react to the cam that moves past it to create the count signal.
    I had another switch in there that was working, but intermittenly the machine would stop and I had to write the turret position in MDI or it wouldn't sense the right turret count and not engage the shot pin.
    Any ideas?
    Dec 2003
    24223
    0V is the 24vdc common, if you have a 3 wire proximity switch, then it requires both 24v and common (0v) as well as the signal wire to operate properly.
    If you have it connected correctly and it does not read a metal flag in front of it, then it sounds as though it is defective?
    Al.
    Albert E.
    Feb 2009
    6028
    Seen some slightly older equipment use pull up resistors. Check your prints, see if it has one. A shorted switch can take them out.
    Jan 2011
    28
    Thank You!
    I'm not familiar with the pull up resistors, what do they look like and what should I look for.
    I should have a new switch early next week, we'll see if it works.
    Dec 2003
    24223
    Most Fanuc control inputs supply the load required for most prox.
    Al.
    Albert E.
  1. Mitsubishi wire type setting for zinc coated wire
    By Futurewire in forum EDM Discussion General Topics
    Last Post: 01-26-2011, 10:47 AM
  2. Mitsubishi wire type setting for zinc coated wire
    Last Post: 01-25-2011, 01:49 PM
  3. Running stepper motor wire with router wire?
    By basskitcase in forum DIY CNC Router Table Machines
    Last Post: 02-19-2010, 05:18 PM
  4. Wire EDM - Wire Type and Size
    By greenchair in forum Uncategorised MetalWorking Machines
    Last Post: 06-17-2009, 07:44 PM
  5. power supply size? for multi wire (total 250 inches of wire)
    By DanOSB in forum CNC Wire Foam Cutter Machines
    Last Post: 03-02-2009, 11:34 PM
