Hi Everyone.
I was wondering if anybody can tell me how flexible these 16mm open linear bearing bushings from VXB might be:
http://www.vxb.com/Merchant2/merchan...t_Code=Kit7443
I'm hoping I could squeeze them a bit to reduce the diameter to 15.875mm to fit the four supported 5/8" rails I just scrounged from scrapped plotters.
My blocks would be designed to vary the clamping pressure around the bushings.
The price difference for 16mm vs 5/8" is $7.95 USD compared to $21.95 USD each and I'm thinking, I might use 12 pieces if I can score more rails, so the savings is big.
The free rails are 56" long and, along with the garage opener screw drive sections I also picked up for free, will probably dictate my design. My machines main function will be milling wood and it looks like the design will be a 4'x4' addressable area.
I can't afford the 5/8" linear bearings right now. If the 16mm won't work I'll build a skate bearing truck system until I can upgrade but it would be sweet to start out solid from the start.
Any observations on this type of bearing or any other advice would be greatly appreciated. I also have some ~175oz-in steppers to start off with and I just started building the drivers.
Thanks,
IZen
