603,783 active members*
2,680 visitors online*
Results 1 to 1 of 1
    Jul 2011
    20MM round bar drilled and tapped
    Looking for a quote on 200 of the attached. Tolerance is critical so 20MM 1018 cold rolled must be used. Bar can be saw cut. Let me know if you have any questions.
    Attached Files Attached Files
  1. RFQ: Stainless steel drilled/tapped sphere
    By jeremy0203 in forum RFQ (Request for Quote)
    Last Post: 06-16-2011, 07:14 PM
  2. Hex Bar Stock turned and drilled/tapped
    By ez3022 in forum Employment Opportunity
    Last Post: 10-01-2010, 12:04 AM
  3. RFQ - Turned Steel w/ Drilled & Tapped Set Screws (Cancelled)
    By AuroraDrvr in forum Employment Opportunity
    Last Post: 04-14-2009, 07:12 AM
  4. Drilled & Tapped Precision Shafting
    By justCNCit in forum Mechanical Calculations/Engineering Design
    Last Post: 12-24-2008, 12:56 AM
  5. Are sherlines drilled and tapped??
    By BriteHarry in forum Mini Lathe
    Last Post: 10-15-2004, 01:36 AM
