I have a requirement for a couple of 5 inch square cooling fans for an older Enshu machining center. They look pretty standard, but unfortunately require 220 volts. Enshu now has a policy that requires a $750 fee to register used machines before any replacement parts may be purchased from them. So buying from Enshu is a last resort solution based on principle alone.
The fans are made by Tobishi pn# S4556m. I have only been able to locate them from a factory in Korea but the shipping cost from DHL was quoted as $525! I probably can kluge together a solution with more easily available fans, but I would like to have a similar replacement if possible.
Any help in this matter is welcome.
Thanks.
