603,939 active members*
2,004 visitors online*
Page 2 of 2 12
Results 21 to 31 of 31
  1. #21
    Apr 2009
    109
    Thank you. So far i'm very satisfied.
    I need to get some more cutting tools and try different materials.
    So much to do and so little time..
    CNC USB controller - http://www.planet-cnc.com
  2. #22
    Oct 2005
    69
    Very nice looking machine!
    Firm, solid look... I`l bet it can handle the metal using apropriate tools.
    Regarding the tools (mill bits..) ask our friend Slowly for info.
    Regards!
    Mitja
  3. #23
    Jun 2007
    33
    Hello Andrej (kroko)
    I want to contact you, your e-mail is?
    Your website has http://www.planet-cnc.com not contacts page.
    I want to buy the hardware and software.
    My e-mail is [email protected]
    Armando
  4. #24
    Apr 2009
    109
    After more than a year it is time for new machine.
    Santa brought me MIG welding machine and decided to build steel frame.
    Other parts will be from aluminium.
    I'll use HiWin rails and ballscrews.
    I havent decided yet but I think I'll use servo motors. Does anybody know this motor and driver?
    Machine will be controlled with CNC USB Controller.
  5. #25
    Apr 2009
    109
    Main design guides were:
    • working table size 600mm x 900mm
    • heaviest piece must have less than 100kg so that two persons can carry it
    • biggest piece must be go through 80cm wide door
    • there must be room for automatic tool changer
    • must be possible to use different motors without big modifications
    • ballscrews and linear rails
    • assembly must be easy with all screws accesible
    • alligments and tuning must be easy with clear reference points
  6. #26
    Apr 2009
    109
    10mm thick steel is welded to main frame. This will be grinded later so that X axes will be level and parallel.
  7. #27
    Apr 2007
    8082
    That's a very nice looking frame design Kroko. Appears to be very rigid.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
  8. #28
    Jan 2005
    15362
    Kroko
    These servos & drives are great DMM Technology
    Motion Control Products - DMM Technology
    Mactec54
  9. #29
    Apr 2009
    109
    Support for tabele is welded. First time I wasn't careful and it twisted because of heat. Second one was better.
  10. #30
    Apr 2009
    109
    This is second table which is straight now.
    Whole thing will be heated in big oven and slowely cooled down to release any internal stress. I think this process is called annealing.
    I must also start working on new CNC USB Controller which will be used with this machine.
  11. #31
    Apr 2009
    109
Page 2 of 2 12
  1. new machine build
    By don_don in forum Automation Technology Products
    Last Post: 02-08-2009, 06:39 PM
  2. New machine build under way.
    By EL34 in forum DIY CNC Router Table Machines
    Last Post: 02-20-2008, 01:41 PM
  3. Looking to build a CNC machine
    By mitchDM in forum DIY CNC Router Table Machines
    Last Post: 11-05-2007, 01:06 AM
  4. Want to build new machine
    By thuffner3 in forum CNC Machining Centers
    Last Post: 02-14-2004, 03:47 PM
