603,350 active members*
3,479 visitors online*
IndustryArena Forum > CAM Software > Vectric > 3D DXF with Cut3D
Results 1 to 5 of 5
    Apr 2005
    3634
    Question 3D DXF with Cut3D
    Any chance that Cut3D will be able to open 3D DXF files?
    I've tried to open a 3D file (won't work).
    Isn't the only diff. between a 2D (X,Y) dxf, & a 3D DXF that the 3D includes 1 extra line for the Z param.?
    Am I missing something?
    Free DXF - vectorink.com
    Aug 2005
    597
    Hi Switcher,
    Cut3D should import 3D DXF files that inlcude 3D Face entities. Many 3D DXF files only include wireframe geometry and these cannot be opened in Cut3D.
    What software are you using to create > save / export the 3D DXF?
    Could you send a sample file to our support email address and we'll take a look.
    Tony
    Mar 2003
    35494
    Quote Originally Posted by Switcher View Post
    Actually, there is no difference between a "2D" .dxf and a "3D" .dxf. A .dxf file is just a generic format of an AutoCAD .dwg CAD file. It can contain pretty much any entity that an AutoCAD .dwg file can contain, including solid 3D geometry. The difficult thing is knowing what type of entity's you'r CAM package can read, and how to get your CAD package to output those entities.
    I use MeshCAM, which like Cut3D, reads 3D faces. In AutoCAD, if I model with solids, I can't export a .dxf with 3D faces, so I have to export as an .stl. In order to get 3D faces, I need to model with meshes, which can then be exploded into 3D faces.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Apr 2005
    3634
    Here is what I was working with " TopoGX "
    Apr 2005
    3634
    I found a 3D DXF file online.
    The file is almost 6million lines long (28.9 MB), I tried to open it with Win. Notepad and it hung, so I used the editor in VB.NET (no problem).
    I then opened the file in Cut3D, that worked very fast.
    Screenshot below.
  1. Replies: 41
    Last Post: 07-03-2022, 07:18 AM
  2. MeshCAM vs. Cut3D
    By henryj in forum Vectric
    Last Post: 06-16-2009, 06:09 PM
  3. News - Cut3D - Low Cost 3D Model Machining
    By Tony Mac in forum Vectric
    Last Post: 04-26-2008, 09:55 PM
